Hello iboats, im having trouble with my newly bought Evinrude engine, and i figures this would be the ideal place to get help.
So i have bought an 1972 Evinrude 50 HP, 50272C Electrical gear switch and throttle control.
I had been sailing for 1 hour or so, sailing with the engine on all different speeds min speed to full speed, and it ran and started flawlessly. Then after a good bit of sailing i was on my way into the harbor again, i was sailing slow as i was almost in there, when it suddenly started stuggling with keeping up i could feel the engine power going down and up for a little when it then turned off. I then couldnt turn it on again, when i turned the key its just made the cracking sound and nothing happended, also sometimes the starter didnt go enough up to attack to the main cranck gear and it would just spin like crazy. So i waited 15-20 min and when i tried there, it started. So i sailed slowly into the harbour thinking that it was just a random little issue and that its fine again, but 2-3 min after sailing in the harbour in stopped again, and this time for good, i havent gotten it started since.
When i try to start it, the starter goes into the cranck gear and starts turning it, but it only turns it for a little and then it stops, then turns it a little, and keeps doing that over and over.
A thing i have noticed is that i cant turn the proppeler, and i have heard from some people that it means that it is set in gear, and it cant start in gear. But i cant change the gear with my control box. Also when the cranck gear turns the little bit it does when i try to start it, the proppeler turns for a little aswell with it.
Things i've tried:
- Checked battery + battery poles.
- Checked ignition, its sparked small sparks so i think it works, though i dont know if the sparks have to be big, but they spark when i hold it on the metal of the cylinder.
Also, im not a boat veteran so i may
Thank you in advance, it would really be appreciated if you would take a little time to help me out.
Sincerly Mathias
Things i've tried:
Sincerly Mathias
