Ok, I want to make sure I get this right. I shouldn't remove the deck, flooring and stringers all at oncew unless I block the hull from undeneath first to make sure the hull doesn't lose it's shape. Is this correct?<br /><br />I have a 1971 Glastron Bayflite model V163. The floor, stringers and transom are rotten. I msut replace it all. The hull has a shelf under the enclosed bow. Under the shelf there is the continuation of the flooring which is also rotted. Under that is the point at which the main stringer starts and runs the length of the boat. I also have a stringer on either side of this one that start about four feet back from where the main stringer starts. In order to replace the main stringer I must remove the dewck from the hull to gain access. If someone could give me a proper order of restoration for these issues I would greatly appreciate it. Such as <br /><br />First the transom<br />second the stringers<br />third the floor<br /><br />Or whatever the best sequence should be.
