Re: Follow-up, four years after short shaft seal discussion
That looks delicious! Is it a grouper? I can't wait for it to cool off a little here. The Redfish and Speckled Trout fishing is the best in the fall.
Won't be needing to buy that SEI 106 after all. My customer was so happy with his engineered quartz counter top and the rest of his kitchen remodeling that he
gave me a complete Alpha One outdrive with stainless steel Quicksilver prop! He said it was shifting fine when he removed it from his boat (which was rotten beyond his desire to repair), so all I need to do is *ahem* replace the Mallory u-joint bellows and exhaust bellows, and the Sierra trim sender/limit switches--all of which very prematurely failed, then replace the gimbal bearing and u-joints which got wet with saltwater, then swap out the lower units, but not before redoing the water pump, then going back through the shift cable adjustment procedures. Easy Friday afternoon project :facepalm:
