cylinder 1# and #3
fisheymikey
I am totally stumped all of a sudden cylinder 1&3 not firing
I have force 125 1988 any idea
maybe just a wiring diagram would help
thx
mike
foodfisher
Re: cylinder 1# and #3
OEM manual doesn't link 1&3 together. Individually 1 and then 3, could be sparkplug, coil, or trigger. Something fishy Mikey, probably me.
Jiggz
As food fisher mentioned, there's no link, electrically between 1 & 3 cylinders nor there is fuel connection either. I believe it just so happens both failed at the same time either with the coils, plugs or trigger.
fisheymikey
can a faulty rectifier do that?
but I think its the trigger is there any way to test?
mike
jerryjerry05
Yes outboard ignition . com or CDI igniton . com both have test procedures.
I found that the connectors on my trigger were bad under the shrink wrap.
It would test OK then not.
I replaced ALL the connectors, even the stator wires and it solved my problems.
