I have a 1995 Force 40 hp outboard, it seems to run fine except the idle speed is a little high, about 1200 RPM. I have noticed a current draw from the battery, a slight spark when I connect the engine battery cable. I have also notice that if I leave the motor battery cable connected that the next week or two the battery will be depleted and need to be recharged.
I have heard that regulator diodes can go bad and cause a battery to discharge slowly over time.
Any input would be appreciated.
Thanks,
Spotlight
Thanks,
Spotlight
