Once again I must bow to the wisdom of the forum.
1986 Force 50 HP
Had a broken water tube, replaced.
Replaced the entire water pump with a brand new one, housing, impeller, the whole works.
Motor isn't pumping water into the motor.
Checked everything before coming online here.
Pulled the pump, made sure the stainless washer(?) was on correctly. found out it only goes on one way. Ensured the impeller was engaged with the drive shaft.
I'm thinking it may be water tube alignment, but this last time, I did my best to make sure the tube was in line with the pump before bolting it down tight.
Still no water coming from the exhaust or my tell tale.
Could the water tube be jumping out of alignment at the last second? Not a lot of room to work in there.
1986 Force 50 HP
