So first off, I searched....and I am not sure if this is even the correct place to post this....
Low WOT...(I know I know...)
Full tune up, filters and timing is good, but I am still getting low WOT...
It is a Mercruiser 260 (5.7) 1985 with Thunderbolt IV Ignition, in a Four Winns Liberator 211 (new to me)
I am only getting to 3800-4000 RPMS, which seems to be the range the most people achieve on here when they are having issues.
A buddy of mine is going to let me use his 19p (21p on it now) this weekend to see if it helps, but from all the reading I have done about this boat, I am starting to think a 21p is what came on the boat originally and would like to fix any other issues before trying a smaller prop.
Current Prop setup is a Quicksilver 48 11070 A40 21P.
Seems after doing some reading that this prop has caused other people issues before?
At 3900RPM, I am hitting 44mph (GPS), although the other day I had 3/4 tank of gas and 4 adults and 2 kids and was only hitting 39mph, which I totally understand the weight difference makes an impact. This is my first "Go-fast" boat, but all the hearsay is telling me this should easily be a 50mph boat.
Next on my list to change is the ignition sensor inside the distributor. From all the back and forth reading about them, it seems that these control the timing advance.
IF this is in the wrong section I apologize, but any help would be Appreciated!
Thanks!
Tom
Thanks!
Tom
