iblandford
- Aug 6, 2013
- 5
Please bear with me, this is my first boat motor, and need some advise on what needs to be done to get it to run right. I believe I have a 1972 evinrude sportwin 9.5. The model number is 9222m and the serial number is 016347. Its running rough right now, and Im sure it could use a tune up. Ive only ran it in a drum so far, but this is what i've noticed. It will start up in neutral, while giving it a little bit of gas. It idles rough and smokes. There is not much water coming out when in idle, but when in forward, it will let out a little more, not a steady stream, but there is a little. The water temp coming out is pretty hot, so I didn't want to run it too long. Not sure how hot it is suppose to be, but figured too hot isn't good. I've looked at the plugs, didn't look terrible, but a little dirty. I figured I should go get fresh gas, and plugs for it tomorrow and try again. What plugs do I need to get? 50:1 gas mixture? any other help would be appreciated. Thanks!
