Capt Mainwaring
- Aug 5, 2013
- 2
Hi, interesting reading the lastest threads on the demon ignition ballast circuit, mine is suffering, 1988 2655 Bayliner-OMC 5.7 in Bristol UK, will start with a jump lead to coil +, grey/ black, red/purple removed from +b post on the coil, it starts half a turn, I have then put the leads back on remove jumplead, it runs ok, when its warm.( I have unplugged the ESA so as to not to have any false drain away, or misfire)
1/ can you say what voltage should be at +b coil from start, 1st turn of the ignition key, 2nd Starter position??
Now my meter readings are 4.45Volts to 8v on start.
having looked at Captain Bobs colour wiring diagram post most helpful
My thoughts are the resistor wire to the altenator or the altenator or I am losing it some where else?
Any details or thoughts gratefully received
