My fatherinlaw had a impeller go bad, i mean that the brass sleave came loose from the rubber which made the impeller stop spining at high RPM. Damage is cylinder 1+4 are at 130psi and 2+3 are at 80psi when i tested it . So i figured a blown head gasket and when i took the head off i can see where it was leaking between 2+3 and just started leaking into #4. everythig else seems fine so im going to put it back together and hope but the question i have is can i reuse the headbolts or are they ounce and done. Thanks and sorry for the long story.
