NoStress
- Aug 4, 2013
- 10
I have a 2002 Mercury 40hp that I attempted to remove the lower end to try and fix a no peeing problem. When I tried to remove the lower unit I was hung up with the gear linkage. To make a long story short I moved it to forward to put the lower end back up until I figured how to lower it correctly.
Now I don't know what gear the lower end is in. My book states the engine should be in neutral. With the lower end out, I put the gear shifter in neutral.
I pushed down on the shifter linkage on the lower end and now the propeller does not seem to move in any direction.
See attachment:
Is there someway i can fix what I messed up?
See attachment:
