powers laker
- Jun 21, 2012
- 10
.Motor is an 85 johnson 30elcoa.
Syptoms:won't stay running under load.
Diagnosed a leaking a choke relay,crack in nipple that holds gas line,replaced gasket and cover,still sick
Lets try carbs:cleanbut needle seat a little worn out, carb rebuild kit:kit installed,rebuilt,
Both cylinders pushing around 118,good there is still hope
Spark is strong.
What are my next steps into diagnosing little Johnnys ailment,I am a carpenter,and don't want to fix it with a hammer.Is it possibly a timing issue,if it is can someone post how to check the timing ,and whatever I might need to buy aimlessly.Tired of watching the algae grow on the pontoons:facepalm:
Spark is strong.
