Aggrivated
- Aug 4, 2013
- 1
Where the throttle and shifter cable go into my 1976 55hp Evenrude motor there are 2 brass rods with a plastic wheel on each cable to adjust them I have a grind going into reverse not real bad but it was not there before I accidently adjusted the wrong one how do I adjust it to stop the grinding in reverse it doesn't do it in forward I WILL mark it when I get it right. If you know how to adjust both please respond
