Re: 69 glastron rebuild
Put the plug on the outside. If it loosens, water pressure could pop it into the boat if the plug is on the inside. Water pressure will hold it on if it is on the outside. The benefit of having it inside though is you can pull it while planing and drain the hull, but if everything is sound, you should never have water in the hull (unless swimmers came in and out of the boat or it rained hard). I had your problem after my rebuild. There was a nasty looking Marine Tex repair on one of my lifting strakes, and I had not bothered with it, I figured it was sound. Nope, it had a pinhole that would allow water to intrude. I ground it off and repaired the hole with epoxy and cloth. I never get water in the hul anymore. Just climb undeneath while on the trailer and inspect the hull for holes, abrasions (any exposed fiberglass from beaching can wick water, so fix that). You may also need to move the boat back on the trailer to expose where it normally sets on the rollers (or bunks), as the trailer could be hiding the damage. Good luck...<br /><br />Also, Mark speaks the truth about the drain plug hole. Mine was nasty, and I cleaned it with steel wool and bought a new plug. I was getting a bit of seepage this spring, and it stopped after I did Marks trick.
