Re: Mercruiser will not work without a lot of revs
Yep, the re-sized photo was smaller than the thumbnail... :facepalm:... Oh well, at least I saw enough to be able to say, completely and unequivocally, that the engine in that photograph is a 3 litre GM engine, and the thing under the round thing on the port side of the engine (flame arrestor, not air filter) is a carburetor... Besides, you provided the engine serial number and I was able to look up what it was (that's the value of the serial number and why we ask)....
Removing carb. Easy. First thing you'll need is the manual.... For that, I have this ->
https://docs.google.com/viewer?a=v&...ZDU4ZS00NzcwLWI1MGYtMTQwMzc3MTJiYTdl&hl=en_GB
Download and SAVE.... Now, open it up to section 5, part B... All about your carburetor.... Page 15 of that section steps through the removal process. If you're happier taking the carb to a shop, find one that has experience with Rochester carbs. Also, take a gasket set with you. Marine gaskets can vary slightly from standard automotive. The gasket set for that carb is 3302-810929. (from a Merc dealer or on-line shop)
If you're up to doing the job yourself, we're here to help.... It's not a difficult job, but you will need a few tools. Small is better when working with these components. The usual assortment of screwdrivers, spanners and simple hand tools is usually enough. NO HAMMERS!!!!
:facepalm: You'll also need an accurate small measure (I use a 6 inch steel rule and a vernier caliper) and a source of DRY compressed air (I use SCUBA tank air as it's about as dry as it gets!). A few tins of carb cleaner (NOT brake cleaner, that stuff's dangerous!!!) and you should be good to go.
Just keep the work bench clean and tidy (and by clean, I mean, CLEAN! Your current problems are caused by dirt, so clean is good
), work slowly and check everything twice, and work in the order the book calls out. And read the procedure through a few times before tackling the job....
As I said, we're here to help you if you think you need it. One more thing. If in ANY doubt, ask, before you screw it up....
Chris.....
