Oshawapilot
- Aug 2, 2013
- 66
Greets all. I'm helping my sister and brother in law sound out a variety of boats with the intention of buying a cuddy/cabin cruiser in the 27-30 foot range for travel on the Trent Severn waterway system.
We looked at a 30 foot cruiser today, 1989. Quite impressive condition for the year, obviously well cared for all it's life, and we were impressed with almost everything. Unfortunately when I lifted the engine compartment the interesting part began.
I knew it had the infamous 3.7's. I'm well versed with engines, I've rebuilt more than a few from the ground up, my 6.5 turbo diesel being the last about a year ago. I've done a lot of reading on the 3.7 and know the issues with the charging system, cooling, etc. This is a last-year 3.7 so as I understand it the cooling system was the larger and more reliable one on this year/model.
The starboard engine starts and sounds good...absolutely nothing I'd be concerned about, however when we started the portside engine I immediately picked up on a knock. It was difficult to pickup exactly where the knock was coming from, that was the worst part, but with so little external on this engine, one must assume it was internal.
Seatrial was totally uneventful. Engines run up nice and smooth under load, synchronize nicely, power output seems even across both engines, and oil pressure was consistent at both idle and high RPM.
So, first off...for those who know these engines, a knock can't be a good thing, but any further insight?
Our idea is this - make an offer on the boat with the assumption that by next spring we will need to rebuild/replace the port engine, and price our offer accordingly. From what I can see, I think I can do a rebuild for between $750-$1500 in parts, so long as the crank is salvageable - the big question given it has a knock, and if it's a main bearing...what exactly is going on in there.
That said, crate engines can be had for $2500 or so....and that's a possibility that they are prepared for and will budget for with a contingency fund.
They are NOT racers who will ever likely run these engines wide open - looking to putter from place to place with the occasional mid-speed cruising. My thought is the engine will probably last until the end of the season (the knock doesn't sound like it's reached the "gonna throw a rod out the side of the block" stage), and then the engine could be replaced in the winter months.
So, thoughts?
So, thoughts?
