I have a 1988 Mercruiser 470 (165HP). I had the engine rebuilt over the winter as the head gasket on the port engine was bad. Both the port and starboard engines are loosing antifreeze when I take them out and run the boat. Sitting at the dock, they are fine. The port side engine is losing about 1 quart of antifreeze and the starboard about 2 quarts, this is on a fairly short ride of less than 30 minutes. The engines are both running good and temperatures are perfect. I rented a pressure tester and pumped the pressure up to around 18 and found no leaks. I did find that I had 16 pound radiator caps on both and from what i have found they should be around 12 so i have replaced them. There is no antifreeze in the oil. There was antifreeze in the bilge but I believe that is because one of the coolant overflow bottles was too full. I corrected that issue. I also had the heat exchanger pressure tested at a radiator shop and they found no problems with it. New gasket between the riser and exhaust manifold. Oh, i also had both outdrives rebuilt with new water impeller, bellow and water lines.
Any ideas? I'm at a loss since I have basically rebuilt 2 engines, 2 outdrives and replaced all of the trim cylinders.
