I bought a 2000 Crestliner Fishhawk and was told I could turn the livewell on and it would fill up and I could then leave it on or turn it off and the water would stay inside the livewell. There is a little spigot thing that you turn to allow water in and turn off to stop water from coming in. There is no other spigot. There is a long plastic tube that you plug into the drain hole also.
Well, I turned it on and it filled with water and worked great. However, I turned it off thinking that the water would stay inside since the plastic tube was in place. However, the water had all drained out after a short time. I thought this livewell was supposed to re-circulate? Or is that only when it's turned on?
Either way, why didn't the water stay in it when it was turned off? Do I have to always have it turned on to keep water in there?
