Boomyal
- Aug 16, 2003
- 12,072
You ever try to fill any hole or scrape with this stuff? First of all it is very hard to mix in the right proportions, in small amounts, because of the different consistancy of the resin and the hardner. It's a 5 to 1 ratio with a 10% variation allowance.<br /><br />Once you take a wild guess about the mix the stuff is so sloppy that it goes everywhere but in the holes. Then when you get it there it does not want to fill the holes, it just pooches out.(at least vertical surfaces) Of course when you try to sand the mess down, everything around it is softer so you sand thru the surrounding gel coat.<br /><br />Grrrrrrrrrrr!
