Any suggestions on what is causing this?
M Mattv203 Recruit Joined Aug 1, 2013 Messages 2 Aug 1, 2013 #1 Any suggestions on what is causing this?
M Mattv203 Recruit Joined Aug 1, 2013 Messages 2 Aug 1, 2013 #2 Re: Motor has rubber melting under flywheel I have noticed on back of the coil packs the silicone is melting also. Any idea what may cause this?
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Aug 1, 2013 #3 Re: Motor has rubber melting under flywheel What are you working on? I can only suggest removing the flywheel and looking.
Bosunsmate Admiral Joined Apr 7, 2012 Messages 6,129 Aug 2, 2013 #4 Re: Motor has rubber melting under flywheel Dont go far from shore! As above and check your cooling system too
