Hi there,
I need some help with my Evinrude 70 hp 1981 (3 cyl) E70ELCIM.
I have owned this engine for many years and it used to ran like a real champ. But last year it started to give me some headache.
Problem description:
It simply does not have the power it use to! It is struggling to get on plane and feels sluggish in the "lower/middle register". Very noticeable when under load.
With only me in the boat it does run pretty decent, but with just one extra person you notice the hesitation right away. It will plane, but not fast enough to have some fun When it finally do plane it runs good, max rpm 5600'ish.
It definitely can't pull up a water-skier or not even a tube.. Which used to be no problem at all.
Doesn't help with pumping the primer bulb or using the choke while trying to accelerate.
So far I have done/checked these things (not in order):
New plugs: Champion L77JC4
New fuel.
New fuel lines.
New primer bulb (it stays hard).
Tank vent open.
Carbs completely disassembled and cleaned (with ultra sonic) blown out with compressed air then rebuild with carb-kits.
Rebuild fuel pump with kit.
New impeller.
New thermostat.
Compression test gave these:
Cyl 1: 120psi
Cyl 2: 123psi
Cyl 3: 118psi
WOT Timing advance seems to be at 16deg with the timing light (not 100% if it is correctly measured as the pointer was taken of by previous owner, I put it back and positioned it as good as I could).
Reed valves looked ok visually when looking when the carbs where of, but I'm absolutely not qualified as a judge of that. Also blew them out with the air compressor.
The motor starts real quick, and it always has! Idling rpm is ok.
The problem seems to be with the lowest cylinder (no 3).
When I spraying premixed gas directly in to the carb no3 it picks up the rpm and the engine seems to run smother (when idling on muffs).
When I do it to the other two carbs the engine almost stalls. Therefor I suspect cyl 3 going lean/starving...or something.
Also when I "choke" the carb no 3 with my hand I feel suction but engine does not respond any different (no change in rpm). When I do it on the other two carbs it (again) almost stalls...
To rule out the carb for cyl no 3 I switched carbs for cyl 1 and cyl 3, but the problem did NOT follow! Still the same result when spraying premixed gas.
Cyl no 3 is still the one that has a problem!
Power pack? Coils? Reeds?
As the motor picks up rpm when I spray premixed gas in the carb for cyl no 3 guess that it has a spark and therefor maybe the ignition can be ruled out??
Also notice that the problem cylinder is the one with the lowest compression value (if that can give you any hint..)?
If someone more knowledgeable can give some new idea or point me in a direction I will be more than happy!
Sorry for the long post, but I guess if you would to have a chance to help me you'll need as much info as possible
Please advise fellow boaters!
Best reg// Ryon13
New fuel.
New fuel lines.
Tank vent open.
New impeller.
New thermostat.
Cyl 1: 120psi
Cyl 2: 123psi
Cyl 3: 118psi
Best reg// Ryon13
