how can I tell if it is a iv or v ignition. replaced the coil still no spark can anyone tell me in simple terms on where to go next. boat was running well and just started to miss and shut off. when got home and checked for spark and had none, turns over good but will not start. Ken
engine ser # is 4-43l1006s-of274722 I checked and when I groung the white green wire fron dist I have spark it tells me the ignition sensor in dist is bad but when I look at them they look different can you give me the part number I need
