Wakko
- Jul 16, 2013
- 48
I did a search both on here and on the Googles and didn't come up with anything other than using standard gear oil. Is that right? I'm going to change the impeller, so when I have to replace the oil do I simply lay the outboard on the side and fill the fill hole until it's full? I presume I will need a gasket where I unbolt it? Thanks for the help, gents, hoping to try this motor out in a few days!!
