I feel stuck on this part of my rebuild. I've already completely rebuilt all of the seats, and the rear part of the engine cover, but I'm stuck on the doghouse. I've looked at all of the big upholstery threads on here for inspiration, and it has helped tremendously.
I need some guidance as to where to start upholstering this doghouse I built. I'm planning to use 1/2" foam on all of the surfaces, and possibly 2" foam on the very top (undecided, maybe stick with 1/2").
I was thinking to just cut out the two side panels first, then one solid piece to go all the way down the middle, from the very top, over through the cup holders, and to the bottom at the deck. I'm not sure if I can get all of the corners tight, especially around the cup holders, if I go this route though, because there won't be any areas to pull and staple around the cup holders.
Note: the box on the very top of the doghouse isn't secured down yet. I'm planning to upholster it separately, then screw it down at the end after both parts are upholstered.
Do you guys have any suggestions? I haven't found anything quite like this to use for ideas.
Just for kicks, here are the bow seats. Not perfect, and I wish I had gone with a striped pattern, but oh well, I'm satisfied with it since it's my first sewing anything ever.
