I have a 88 85 hp force. While on the water Sat. she started misfiring, running poorly. However, at high idle motor runs good and doesn't miss. I've cleaned gas tank & replaced gas with fresh high test, changed water separator filter, and installed new spark plugs. Compression is good on all three cyl. and I have blue spark on all three as well. So, firing isn't an issue, all three cyl. are hot.
When I back off of high idle and tap on no. two carb, motor perks up, then after a few seconds goes back to missing.
Would this be trash in the idle circuit of carb? I'm shuckin and jivin' trying not to pull carbs off.
Thanks for any and all help.
David W.
David W.
