I am getting my boat ready for the season and here is what is going on. So far, I have only ran the boat out of water in my driveway.
Engine SN: OD524716 Thunderbolt IV Ignition
The engine starts fine. I let the engine get up to operating temp and let it idle. It will idle fine for around 5-10 minutes, sputter for a minute and then shut off. I hooked up an axilery gas tank and it did the exact same thing. I have been able to recreate this problem almost 10 times. When the engine stalls, it can be tricky to start. ESP, if I leave the muffs on and the water running. If I turn the water off and let it sit for a couple of minutes, it starts right up. If I leave the water on and let it sit for a couple of minutes, it can be tricky to start.
When the boat is idling in the driveway the temp gauge only shows ~135*. If I idle the boat higher the temp will rise to about 145. I can also get the engine temp to rise to 145 if the slow down the flow of water to the muffs using the value on the hose. I have not found the perfect flow of water to get the engine to idle at the proper engine temp. The engine has not stalled when the engine temp reads ~145* due to increasing the idle or cutting back the water to the muffs.
On the water, while running the engine, the engine temp gauge usually shows ~155.
So, is running the engine at a cold engine temp for an extended period of time causing the engine to die at idle? I have a well and the water coming out of the tap is cold. The combination of cold water and pressure from the hose is keeping the thermostat open and the engine running pretty cool.
I am a crazy for even thinking this?
I know with Fuel Injection computer controlled engines there are controls with in the PCM which modify spark and fueling based on engine temp to encourage the engine to warm up faster, idle higher, etc. Is the engine reaching some sort of weird glitch in the Matrix where it expects to be running warmer but it's not so it gets fussy and putters out?
Pretty much everything else looks good.
I changed the plugs, engine oil, impeller, water/separator fuel filter, fuel filter, the battery gauge shows good voltage, and the engine will rev strong.
I believe the thermostat is working properly. I cut the water to the muffs and let the engine warm up to 180*. When I turned the water back on, the temp gauge went down to 155* pretty fast. As I keep the water running, it slowly creeped back down to 135*-140*.
Now that I think of it, I am going to test the thermostat in a pot of hot water...
Any other suggestions?
