redjmp
- Mar 16, 2005
- 536
I want to convert an 898 to center rise aqua power manifolds.
I have tried to use the existing tstat housing with 3 outlets per side and plumbed the new manifolds to flow kind of like the log ones did except from low back to high front with solid riser gaskets and the riser being fed by the top most outlet.
I used the Clymer diagram...
Engine runs fine and keeps around 170 even at wot but the manifolds are so hot I can smell the paint cooking.
Scalding hot to the touch.
Obviously something is wrong.
I have included the diagram I used and a pic of how I have mine plumbed and also a pic of a stock 898 which shows a different arrangement than the manual I think...
Is the picture the right way or is the manual correct?
I have searched other threads and have seen someone use a tstat housing from a Volvo and just run 1 line to the front of the manifolds with pass thru riser gaskets.
Just wondering if the is how Volvo does it as it appears they use this arrangement and the same housing on virtually all their setups.
Is this is any better than the way Merc has tried to do it with so may various tstat housings?
I would rather not have to go through the expense of buying a new housing and replumbing everything if I can avoid it.
