lkgboater71
- May 26, 2012
- 14
Hi all -
I have a 2006 Merc 5.0 TKS with an intermittent alarm. From what I understand there are 3 reasons the alarm would go off.
1) Oil Pressure. Always between 40-80.
2) Temp. Varies between 160 - 178 depending on load. I just replaced the thermostat to be sure that wasn't the issue and impeller is new this season.
3) Gear lube level. It's about an inch below full.
Any way to determine which alarm is actually sounding?
Attached is a picture of the spark plugs I just pulled out (A/C MR43LTS) with about 40 hours on them. They are from cylinders (starting from right is #1 cylinder and the left is #7) 7,5,3,1. The plug in cylinder 5 looks like it hasn't done a days work in all 40 hours. It looks more dramatic than in the pictures. Plugs in cylinders 2,4,6,8 look like the ones in cylinders 1,3,7. I just replaced the cap/rotor/wires/plugs as well.
Could there be something wrong with cylinder #5? Acceleration seems sluggish.
Thanks!
Thanks!
