jeff.nelson83
- Mar 23, 2012
- 40
Removed the drive unit from the bellhousing to grease u joints and check things out. Getting ready to install the drive and had some questions.
1st. Cleaning the gasket material from the bellhousing? Does it matter if the black paint is removed from the bellhousing while cleaning the old gasket material off?
2nd. Manual state that i should glue the big oring in "that goes around the driveshaft" or else it could leak?
Looking for real world advise, let me know how you guys install your drives. Thanks
