Re: fuel injected sea ray 2001
I asked 3 questions (silly me, I should have used 3 posts), but you still managed to answer none.
Again....
1. What do you mean by 'getting into the oil'? (Oil should be in the engine, not the engine in oil).
2. What sort of 'boat guy'?
3. How did he come to the conclusion that the engine needs to be replaced? For what reason?
If you mean, the engine is using/burning oil, then a bad injector or fuel pump CAN NOT cause that. Only bad piston rings or valve guides can do that. Neither of which would necessitate an engine replacement.
You need to do a cylinder leak-down test, and run a vacuum gauge to check for worn valve guides.
I'll run the risk of asking another couple of questions.
4. What instruments did these mechanics put on the engine? Given it's an MPI I would, at the very LEAST, expected a scan tool or a laptop with diagnostic software. Either of those would have picked up a bad injector.
5. How is the engine running? Has it lost power, does it idle badly?
Chris......
BTW, Welcome to iBoats.
