KCKracker
- Jul 28, 2008
- 280
blue lid evinrude 30 hp
ok let me elaborate. buddy brings me his motor and says he was cruising along and then it made a noise, looked back, saw some smoke and he shut it down. then its dead.
i immediately see a few slightly melted spots on his wore shielding so i pull the flywheel, i find the power charge coil is partially melted.
ok, so this thing had to have gotten hot. he said it was peeing water so maybe the T stat is stuck.
Issue: with the spark plugs in you can BARELY pull the cord, plugs out its easy. This started as soon as the other issue. i dont understand is there a compression bypass or something that could be stuck? i dont get why this is happening.
