I have the pin type prop set-up, a 1977 Century, 235 HP, 351 Ford V8,, OMC outdrive, and can only find about 3-4 different pitches, all too low for what I want, 16 pitch being the highest.....Why do they not go up higher in pitch for the pin type prop set-up? After 77, 1978 for example you have a wide selection of pitch for props, 21 pitch and higher,......?
Can one pound out a 20 from a 16 or 17 pitched prop? I want more top end, higher cruising speed, please help.
Later..........Chad on the Shadowy St. Joe river.
