bluenoseboater
- Sep 21, 2010
- 13
Hi,
I have a 1982 Mariner 3-cyl 70 hp. Was towing tube for awhile and running hard when suddenly lost power, and motor died. Would not turn over until it cooled down. Would sort of run, but not enough to power the boat. Left overnight, and ran a bit today - would run for a few minutes, then begin to die, and eventually the same thing. This time I noticed quite a bit of steam coming from the exhaust, so I suspect a head gasket. When I got home, I checked compression and found that the top cylinder had none (maybe 10 lbs). Other two were over 100 psi.
I have been looking online for a head gasket but cannot find one. Almost seems that this engine does not have one. Found references to water jacket gasket but not head gasket. Surely there must be a head gasket? Hopefully that's all the damage. Water pump is in good shape and lots of flow from the tell-tale. Any help or suggestions appreciated.
Thanks
Thanks
