I have a 1976 Reinell 26' full cabin cruiser with twin 175hp 302's with electro shift. One out drive is bad (frozen pretty bad) so the owner before me picked up a donor drive. My question is I can't find any reference to the outdrive stringer part numbers. Only the ones on the motors come up.
Can someone tell me what year and gear ratio part #982141 is. This one has a spur gear for turning so I'm sure it was on a smaller boat.
This boat has dual station hydraulic steering and with the ram under the seat behind the inside helm. So I know I will at least need to remove the spur gear.
I measured the drives upper and both were I wanna say 14" or at least the same so I don't think I have short
The stringers on the boat our part number #981059 and they match
The engines are 90229M and they match.
So can I use the donor drive? Will my final gearing be on assuming the same pitch prop? Or if it's different could I use a different pitch prop to compensate?
