java230
- Jul 18, 2013
- 295
The boat is new to me, and I am just wondering if my speeds sound normal/to be expected. And if a different prop may be better suited to me.
Id like a little more speed, but not sure if i can get it.
Boat:
1983 Coho 134, a 13' whaler clone.
Motor 1982 Mercury 2 stroke 40 HP (i think it has 2:1 lower, best i could find by searching around).
Prop is a Michigan 10 1/4" 14 pitch, Aluminum.
Package should be 6-700 lbs. (I can easily lift one side while on the trailer) I may try to weigh it.
My Wife, 4yo Daughter and I, and our gear, id estimate it about 600lbs total.
Planes and does about 20 MPH WOT, via GPS. I hit 21.2 with the wind and calmer water.
No Tach at this time. No power tilt/trim, the trim rod is in the 3rd hole. It does have dolphin fins on the AC plate. AC plate is nearly dead even with keel.
EDIT: after adding tach, WOT is about 3850 with above load at 21.5 mph.
Boat:
