Hi All,
History... Pick up this Chris-Craft Scorpion with a 1990 200 hp Black Max a couple months ago. Rebuilt all cabs, rebuilt fuel pump, changed fuel lines from tank to carbs, changed plugs, and replaced fuel water separator. Tank was empty when i got it so no junk in there. Took the boat out 4 times over the course of July so far and has ran great no issues. Saturday night was going to head out again and the motor would die... ie. fell flat on its face beyond idle. In fact, before i rebuilt the cabs and fuel pump it had the exact same symptom. It was then hard to start after that, once started i tried to get going again and it sounded like it wanted to go but once i hit 1500 rpms it died... i tried squeezing the bulb but its hard as a rock and trying to pump it did not change how motor behaved. Is it possible my fuel pump died again? I plan on looking at it after work tonight and cannot help but notice this is the same way she ran with carbs full of junk and a bad fuel pump.
Also... Boat has 2 new batteries... one starting ... and a house battery... + oil injection had been bypassed by previous owner... running pre-mix 50:1.
Thanks,
Eric
Thanks,
Eric
