I have a Lowe Suncruiser Trinidad 200 with a 50HP Merc big foot engine. I believe there is a loose wire that prevents me from lifting the motor using the throttle handle. I can lower the motor but not raise it. The switch on the motor itself works fine. The question... Can the throttle switch be repaired or replaced by itself or must the entire throttle arm be replaced?
