The lower unit oil on my 1970 60 HP was showing water so I replaced the drain & vent screw gaskets as well as the water pump & seals since the impeller was original.....and added a "pisser".
To complete the job I ordered the shaft seals, bearing housing O ring and retaining bolt O rings. While disassembling 3 of the hex bolts came out but the head on the last bolt stripped (rounded corners). I tried a metric Allen wrench but it was too big and I did not have a grinder available. Next I tried drilling the head off but have only managed to dull the $18 hardened bit I purchased. I've resharpened and tempered it several times but the hex head remains. With hinsight I should have tried grinding the bigger Allen wrench instead of drilling. I also tried a Dremel grinding wheel which promptly sacrificed itself.
Any thoughts from the experts ? I know there comes a time to "let go" but that would be painful since I overhauled the top end last year.
Thanks,
Bumpa 53
Thanks,
Bumpa 53
