I have a 1984 50 hp merc. Started running funny, no power for awhile, then it would be fine now no power at all. Did carb kits for peace of mind and found white/blk wire broken to the trigger. Replaced as much of wire as I could and then tested for spark. 1 and 2 are great 3 fires every 3 seconds and 4 almost nothing.
Test I have tried with multi-meter using info from this site.
Ohms between brown&white/blk .820k
" " Violet&white. .788k
My meter was set on auto in ohms. The decimal thru me off. Am I reading it right?
Cranking test of blue stator wires 250 volts
" " Red stator wires 33 volts.
Could someone please point me in the right direction. Thank
