Hi All,
Specs: 1985 OMC 3 liter (140 hp) with a Stringer 400 out-drive on a 17ft Glasscraft.
Problem: Melted exhaust hoses (boots) and Exhaust Seal (flapper)
Took the boat out for the first time after winter and after about 5-10 minutes I noticed we were taking on water in the bilge. Turned on the bilge pump on and headed for shore, soon after the engine compartment stated pouring out black smoke from the melting rubber presumably.
I was monitoring the temperature gauge closely prior to overheating and all was normal, but once the smoke stated billowing out the temp gauge shot up. I suspected that the t-stat had been stuck, which caused the riser to melt the rubber components and then released which allowed the water to flow again and in turn flooded the bilge.
As I now understand, there should be water flow regardless of whether the t-stat is opening so my first question is:
What conditions would have caused the riser to heat up so much that it melted the rubber hoses and and exhaust seal? I suspect the impeller but then how was there enough water flow to flood the bilge?
Secondly, I'm looking for some advice on the easiest way to access the area where the exhaust flapper should be, to replace it. I already have the out-drive off but it looks like I will need to remove the intermediate housing, I just haven't been able to find many schematics or help on the exhaust seals for the pre 86 3 liter OMC and stringer drive.
I do have an original factory repair manual, but it shows nothing on the exhaust seal.
And lastly, are any other areas that I should check out as potential causes or that may now have potential problems as a result of the overheating.
Thanks in advance,
Scott
Sorry about the thread hijack asperk, but it had the only schematic i have found that actually showed the exhaust seal(flapper)
Pics below
Thanks in advance,
Scott
Pics below
