Sunsetrider
- Jun 12, 2011
- 299
The two vents on the forward cabin top on my Albin 25 went missing by the PO *you can se the patched hole on the stbd cabintop below) and I am going to replace them with this:
NICRO #N28810, 3" WHITE AIRVENT 500 The Chandlery Online
The existing vent holes are a titch under 4 inches in diameter and the Nicro vents require a hole of 3 3/4 inches. My only thought so far is to find some firm, 1/2 inch thick closed-cell foam weather stripping to line the hole with, which will compress when the vent is installed. Better ideas?
This looks like it would work quite well:
http://www.homehardware.ca/en/rec/index.htm/Hardware/Builders/Weatherstrip/Foam-Tapes/1-4-1-Self-Expanding-Multi-Foam-Weatherstripping-Tape/_/N-ntjslZ2pph/R-I2395112
