1988 Mercury 9.9
0b243714
Hi,
I changed the impeller including the lower housing, motor was placed in forward prior to disassembly. I removed the shift shaft completely from the LU during the process and turned the propeller, now I am unable to reposition it correctly. With the water pump housing back on, I can move the shaft up and down into three positions, but only neutral and reverse seem correct, forward ratchets. Angled side of shift cam is facing propeller. Unsuccessful after multiple tries.
I have the manual (from here, thank you), I could not find the answer doing a search, I may have used wrong keywords.
I appreciate any advice.
0b243714
Hi,
