O.K. I sanded the boat with 400 grit wetsand paper, cleaned it, and repainted with 2 coats or paint. I am going to apply at least 3 more coats. Once that is done I will sanding it again using 1500 grit sand paper. What polish do you all recommend for polishing the paint after using the 1500 grit? Thanks for the help.<br /><br />James
