I've never had issues with this motor before. It has been in storage off and on over it's 20 years but always after cleaning the carbs, it's never gave problems.
This year I started fishing again and about 3 months ago I cleaned the carbs and went "boating". It ran good as usual for about 8 trips (all day bass fishing) and never an issue. I needed 2 cycle oil and got Penszoil syntheic. I used to use lubrimatic 2 cycle oil but couldn't find it at the time. Since I've started using penszoil, I've had issues, whether the oil has anything to do with it or not, I don't know. I still mix 50:1.
Here's how my problem goes:
1st time I was wide open throttle (everything prefect so far) headed to the ramp at the end of the day and all of a sudden without warning, the boat died. It would crank but not hit a lick at all. I used the trolling motor to get to the ramp. I got it home, pulled the plugs and they were black. I cleaned them and checked for a spark and had spark. I reinstalled them and hooked up the water hose and after cranking for a total of about 2 minutes (not continous), it started and ran normal.
I got new plugs and ordered new gaskets for the carb bowls since they may have been leaking a little.
2nd time out on the lake, the boat ran fine.
3rd time out, needed gas and oil. Went to the lake and rode to first fishing spot (5 min ride). Then rode to 2nd fishing spot (10 min ride). Went to start the motor and it would crank but not hit a lick again, just like 1st time. I pulled the plugs right there and cleaned them off (just a little black), put them in and motor stated for about 10 secs and just died instantly without warning as ususal. Pulled plugs again and they were clean. I cranked and cranked but it wouldn't "hit" at all. Got pulled to ramp.
Got home and hooked up the water and the motor did as 1st time. It stated after about a couple of minutes cranking, run for about 10 secs and just dies without warning. After a few minutes it would start and run for about 30 seconds or so and just die. I changed the hose and pump bulb from the tank to the motor and still the same thing.
For it to just die without warning has me stumped. Any ideals?
93 Force by Mercury, Model H090412NX
