Re: Alpha One Gen 1 - pressure test
You have both pressure and vacuum on that gauge. Seals generally only work well in one direction. That's why you have back-to-back seals on the prop shaft and drive shaft. The 'inside' seal stops oil getting out, the 'outside' seal stops water getting in. It's quite possible to have an outside seal leak and get water in the drive and still have the drive show a perfect pressure test. I prefer to do both pressure and vacuum for that reason, and as you have both pressure and vacuum on that gauge, it will only cost you a few minutes more of your time... Just be aware that the shift shaft only has an oil seal on it. When they get a bit older they can fail a vacuum test. (I usually replace it if it fails anyway).
One more thing. When anyone replaces back-to-back seals, they should ALWAYS fill the cavity between the seals with a marine grease. It helps prevent the seals from burning.
Chris.......
