Re: Will a mercury prop 48-88440-19 work on my 1990 90 HP Force outboard
Probably not! Most larger Mercury engines use a 4 1/4 inch geargase diameter while Force uses a 4 inch diameter. The ONLY exception I know of is the "small" gearcase Mercury 90 horsepower.
Before buying call the manufacturer and see what the prop hub diameter is.
