Hi all I have a 1982 Johnson 175HP Outboard on a 18 ft Hydrodyne.
Heres the problems on my previous Key ignition switch it had M1, M2, B, A, C, and S. My new one has the following as you can see in the picture. M1, M2, B, A, C, and I.
And I'm redoing all this because my boat after redoing the wiring didn't start this year so I'm putting a new one of these on.
My first assumption was I and S were meaning the same. Ignition and starter, please correct that if I am wrong.
I hooked up everything the way it was and the things that are troubling me are the B and I connectors.
The B had two wires coming in one big red one from the engine cluster of wires (this makes sense I think this should be there) and it had the rogue yellow wire coming in from the power pack(see the second picture to see the yellow wire running in and where its attaching. I have NO IDEA what the heck its doing, may someone could shed some light here.
The I (on the new switch or S on the old one) has a wire that looks to be going to the trim adjustment (up or down) for the outboard. I have no idea why that would go there? Shouldn't that be on the accessories one.
One another note my trim used to move up and down without a key in it so I think that explains why it used to work like that I think (not really sure).
So my question is does that yellow wire going to the power pack need to be going to the I position on the switch (is that what starts my boat)? And should the trim adjustment just be a accessory when I turn the key halfway?
Sorry I'm at wits end and I wish I could test this without hurting anything. I have a volt meter and a smaller 6v if anyone has ideas on what to try. Thanks so much for any help!
