SEGAangler
- Jun 23, 2013
- 69
The boat I recently bought has a Land & Sea Torque Shift Auto Pitch prop that I need to remove (previous owner said it wasn't "acting right"). It is seized on the prop shaft. I have read many of the threads about removing props and have pretty much realized it's gonna have to be cut and/or burned off. The part where the cams are....is it safe and/or possible to cut these? I'm not quite sure exactly how the prop operates so I don't know if the cams are under stress or pressure or what kind of material they are etc. I have started cutting but stopped until I got more info about this. Any advice would be helpful. Any burning will probably be done by someone with more experience but I'd like to attempt to do it myself 1st.
