Hello All,
I recently picked up a used boat and overall it seems pretty solid. It's a 1998 Stingray with 5.7L Mercruiser with an Alpha One outdrive. While doing the inspection, I had a mechanic come down and give everything the once over. He gave the boat a solid thumbs up but did point out that the starboard riser was running hot while the port was cool. He suggested there was likely some blockage somewhere as they should both be cool to the touch where the starboard was pretty warm (you could only touch it for about 5-10 seconds).
I then went to a boat shop to buy new impeller, etc. (boat had been sitting for a couple of years) and the mechanic there said it was normal for the boat to run warmer on one side.
The boat seems to run about 160 according to the gauge but I need to check the gauge to make sure it is working because I never saw it hit any other temp, even after sitting for a while.
In any case, should both risers be running about the same temp and be cool to the touch (not cold, just not hot).
Thoughts?
Regards,
Java
Thoughts?
Regards,
Java
