Re: 3.0 Blowing Head Gaskets
I am looking for any ideas out there. I have a 1998 Mercruiser 3.0 181 CID. I overheated a month ago, and blew the head gasket between the 2nd and 3rd cylinders.
What is your engine serial number?
What did you set the ignition timing at?
What spark plugs did you use?
Be sure everything mentioned above is done correctly then follow the Mercruiser service bulletin link below to a T.
http://www.boatfix.com/merc/Bullet/98/98_14.pdf
Cliff notes,
Engine Models,
1997 3.0LX Sterndrive Engines: S/N 0K001529-0L000000.
1998 3.0L Sterndrive Engines: S/N 0L000001-0L097000.
NOTE: The timing change in this bulletin is to be done only on engines listed above that
have had a blown cylinder head gasket as described in this bulletin. It does not affect any
other 3.0L or 3.0LX engines.
Situation,
MerCruiser has had several reported cases of cylinder head gasket failures that have blown
out toward the exhaust/intake manifold on the port side of the engine.
Inspection,
The most common cause of this type of head gasket failure is detonation. Usually, the head
gasket is the only part damaged. This means that the engine can be repaired by using a new
head gasket. Also, the repaired engine must have the initial ignition timing retarded to 1?
ATDC. Please follow these guidelines during the repair.
1. With the cylinder head off the engine, make sure there is no damage to the cylinder
walls, pistons, valves or cylinder head. If there is no internal engine damage, install a
new cylinder head gasket.
2. Torque cylinder head bolts to 95 lb. ft. (129 N?m) following the torquing sequence in the
engine service manual.
3. Make sure that the correct type of long reach spark plugs (AC-MR43LTS or equivalent)
is used in the engine. Be sure the spark plug gap is at .035 in. (0.9 mm).
NOTE: The use of short reach or wrong heat range spark plugs can cause detonation.
4. Be sure positive and negative battery cables are clean and tight, both on the battery and
on the engine.
NOTE: Loose or dirty battery cable connections can cause higher than normal alternator
voltage output. This higher voltage may cause the engine timing to advance more than normal.
NOTE: Follow procedures outlined in engine service manual for doing step 5 and 6.
BEFORE setting the timing be sure to do the following:
? Unplug the shift interrupter switch leads from the engine wiring harness leads.
? Plug engine wiring harness leads together.
? Install the Timing Jumper Lead.
Failure to do the above can cause an incorrect timing to be set on the engine.
Page 2 of 2 JULY 1999 98-14
5. Reset repaired engine?s initial timing to 1? ATDC.
6. Check engine idle rpm. Reset idle mixture and idle rpm back to specifications if required.
7. After the engine is running, again check the alternator?s voltage output to the battery.
If the reading exceeds 15 volts, check the charging system. Be sure that the battery
cable connections are clean and tight.
8. Apply Timing Change Decal, P/N 37-861829, in a visible location on top of the rocker
arm cover.
9. Destroy the old timing specification of 1? BTDC that is on the engine specification decal
that is on the flame arrestor or cover.
10. If the engine has a Closed Cooling Kit on it, make sure the thermostat that is in the engine
is a 140? F (60? C). Change if necessary.
